Autoscaling
I finally found out how to autoscale my 2D symbol objects. I add MUL2 GLOB_SCALE/96,GLOB_SCALE/96 to the 2D script (I drew original lines @ 1/8" scale so that's why I'm adding /96 to the script.). The problem I'm having is when the scale of the file is changed the object moves ever so slightly and is not at the original location. How do I fix that problem?
Thanks fo all and any help,
Michele
2 Replies 2
Michele
You need to make sure that the object is scripted at the origin...not some offset distance from it.
Dan K
Thanks for the help. I thought that might be the problem. Thanks again for taking the time to answer my question.
Michele
