Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Aussie John
BUG - Help needed to debug Object label 10
if you refer to http://archicad-talk.graphisoft.com/viewtopic.php?p=74260#74260
you will see my complaint about object label 10 which is causing a crash when used in a section and then viewing the layout.
There may be something in the 2d script causing the problem. Any ideas?
thanks
Cheers John
[/size]
2 Replies 2
Aussie John
Comment out line 10
and the crashing stops.
add2 label_position[2][1]+label_position[3][1]+symb_a_size/2,label_position[2][2]+label_position[3][2]+symb_b_size/2
Not sure can do anymore apart from loose the centring feature
Cheers John
[/size]
Frank Beister
Sorry. Better reading the complete links before.
