Display malfunction of Graphisoft ID dashboard
Learn more
Tom Krowka
Bad BIMcomponents site
See the attached JPG file for a window that came up when I tried to connect to the BIM components portal through the object library. Is it possible the site has been hacked?
Anybody else have this problem. Am a bit hesitant to connect.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
3 Replies 3
vistasp
Tom, if you change the web address from <https://bimcomponents.com/> to <http://bimcomponents.com/> does it load without the error?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Tom Krowka
Have not tried it. But have used this site many times in the past, why would it suddenly be a problem site. I never had to change the address before today.
Thomas@wkarchwk.com
www.walshkrowka.com
vistasp
I just discovered that if you put in www at the start, it works even with https so it's possible the SSL certificate have been registered to <www.bimcomponents.com> instead of just <bimcomponents.com>
Either way, since we don't input credit card (or any other sensitive) information at that site, I wouldn't worry too much about it.
= v i s t a s p =
bT Square Peg
