We value your input!
Beta objects
My first objects for downloading is almost ready. If someone want to try them out, feel free.
please tell my what i can improve on this early stage of scripting.. Thank you.
4 REPLIES 4
David Maudlin
omar:
A few problems while loading the library (with the ArchiCAD 15 Library):
1. There are 2 copies of the file "Master_GDL_MyMaterials.gdl" resulting in a Library Report error.
2. There are about 16 missing textures that are called for in the Master_GDL_MyMaterials.gdl file, leading to multiple errors when loading the library. These textures do not show as part of the added materials (they are used for the define texture "TextureXX" part of the script), so I am not clear on their use. Report:
Can't find picture file: Brick Running alpha, called
 at line 2546 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Textured render white, called
 at line 2574 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Concrete alpha, called
 at line 2620 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Limestone, called
 at line 2645 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Marble Carrara, called
 at line 2674 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Granite 3, called
 at line 2702 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Granite 2, called
 at line 2729 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Shingle Asphalt alpha, called
 at line 2753 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Wood Grain pine alpha, called
 at line 2902 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Wood Grain Walnut alpha, called
 at line 2932 in the 2D script of file Master_GDL_MyMaterials.gdl.
 at line 2962 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Tiles Floor alpha, called
 at line 3048 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Leather2, called
 at line 3115 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Fabric, called
 at line 3139 in the 2D script of file Master_GDL_MyMaterials.gdl.
Can't find picture file: Stående Tømmermannskledning, called
 at line 3354 in the 2D script of file Master_GDL_MyMaterials.gdl.
The non-english parameters limit the market (and my understanding of their intended use), but that may not matter for your intended purpose.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Something wrong happened to the master file. I make a new one.
Thank you David...
I will upload a new file in a bit..
maybe it works better now?
David Maudlin
omar:
A problem while loading the library with the ArchiCAD 15 Library: There is still a missing texture that is called for in the Master_GDL_MyMaterials.gdl file, leading to multiple errors when loading the library. Report:
Code:
Can't find picture file: MN_BØK, called
 at line 258 in the 2D script of file Master_GDL_MyMaterials.gdl.
 at line 287 in the 2D script of file Master_GDL_MyMaterials.gdl.
Also, a pop-up list rather than the On/Off switch for certain options (for example Flushlie-Flushfront hjõrne > Flushfront (on) Flushline (off)) would be a better interface choice for those types of options.
The Custom Settings panel is cropped when this side of the dialog box is minimized in width.
The non-english parameters limit my understanding of their intended use.
Not a thorough review but HTH,
