2021-07-15
		12:19 AM
 - last edited on
		2023-05-24
		12:24 PM
 by
			Rubia Torres
2021-07-22 12:56 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-07-22 01:54 PM
2021-07-27 03:04 PM
Minh Nguyen
GRAPHISOFT
2021-07-27 06:07 PM
mnguyen wrote:For my circle window, I used the Solid Wall option and changing the projection did not change the 2D appearance. Then I selected Custom Closure and tweaked it and I was able to get it to look right, but again the various projection modes did nothing to change the 2D view.
Dear Todd,
In the previous answer, I demonstrated the options using Archicad 24 USA. The option should be available using Custom Closure.
The windows in 2D are usually shown assymbolic, meaning they are only a 2D representation rather than the exact projection of the windows.
To have the exact presentation in 2D, we can change its Floor Plan Display settings toProjectedor Projected with Overhead
There's a caveat though: the windows will be shown at as if it was cut by the Floor Plan Cut plane, so for a circle window, you may find it not cut through the center.
Regarding the brick sill: Could you share with me a screenshot of the Window Settings show the greyed-out option?
Best regards,
Minh
2021-08-02 01:01 PM
Minh Nguyen
GRAPHISOFT
2021-08-03 03:46 PM
