2004-10-07
02:45 AM
- last edited on
2023-05-24
12:49 PM
by
Rubia Torres
2004-10-19 09:40 PM
laszlonagy wrote:Hi Laszlo, that's exactly what i said in a previous post.
Another workaround is to duplicate the Material you use for the Window's Wall piece and apply this newly created material to it. This way you will have two identical Materials which have different index numbers so ArchiCAD will consider them different and will not remove the common edge.
Olivier wrote:
Another way, may be easier, if you need to use prism_ command.
Make a copy of the first material, and use it for the second object.
Lines will show, without changing any code.
2004-10-20 04:21 PM
Olivier wrote:Sorry, I was tired yesterday evening, I didn't look carefully enough.laszlonagy wrote:Hi Laszlo, that's exactly what i said in a previous post.
Another workaround is to duplicate the Material you use for the Window's Wall piece and apply this newly created material to it. This way you will have two identical Materials which have different index numbers so ArchiCAD will consider them different and will not remove the common edge.![]()
