Building sliding doors
I am trying to build glazed sliding doors with CADImage Door builder. but It's really hard to make. is there any better options to make?
Using AC12 AUS
6 REPLIES 6
Same in Aus as US?
08 30 00
Specialty Doors and Frames>D2 Sliding 12
Use door panel>(No Grill) with only stile and sill and put glass in the middle?
lec
Ben
What particular aspect of creating the doors are you having trouble with? I use DWB all the time, the only issue is that sometimes the doors will show as outside the wall on plan but inside in 3D.
what kinda sliding door are you trying to make??
the AU essentials library have most.
theres a download in the depository also for larger stackers if thats what your after??
The sliding doors are gonna be aluminium framed glass sliding doors
do u have the AU essentials library? they have sliding doors in it alread
in both AU library 11 and 12
