CUSTOM WINDOW PROBLEM
I'M TRY TO MAKE A CUSTOM CURVED WINDOW THEN WHEN THE WINDOWS WAS CREATER AND PUTED IN THE WALL THE WALL HOLE ITS A SQUARE NOT THE FORM OF THE SHAPE OF THE WINDOWS
2 Replies 2
Srinivas
have a look at this topic
http://archicad-talk.graphisoft.com/viewtopic.php?t=14031&highlight=
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Ben Odonnell
Or you could model a slab, same shape as the overall window, make it the same thickness as the window as well.
Under listing and labelling, in the slab selection settings, change the ID of the slab to wallhole. Save your 3D model as a window.
There you have your fix.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
