CUTPOLY, CUTPOLYA, CUTFORM, in AC 9
I have several objects I made in AC 6.5 which I updated to AC 8.1
They worked in both versions. I had occasion to use them in AC 9
but they fail to process in the 3D window and I get two error
messages "internal error in generator function at line.... of file...
(system error -1) and the library part was not converted properly.
When I open the object in the library editing environment and
check the 3D script using "check script" there are no errors
reported but when I open the 3D view I get the same
internal error.
The problem is with a CUTPOLYA statement because if I comment
out this one statement the part proccess with out a problem.
I have tried changing the "d" value, rotating the command
180°, changing the command to a CUTPOLY command, and
changing the command to the CUTFORM command
but as long as the target element is within range or the cutter
I get the same error and the object fails to show in the 3D view.
I can't use group operations because I want the cut edges
to not show.
Has anyone run into this ?
Does anyone know of a fix or work-around ?
Thank you,
Peter Devlin
5 Replies 5
Frank Beister
Can you post some code to it or send me the object? Without at least the CUTPOLYA-command there is less to say.
I have mentioned a crash in AC9 and AC10 in a certain parameter constallation in the CUTFORM command. Can't say which, because it was a graphical changed parameter, but maybe it has the same source.
Have you tried the simple command in a naked object?
Have you print out all variable values, which are part of the command?
AC9 is much more sensible than earlier versions. Maybe it is a script error AC didn't harm in AC8-.
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
Hello Frank,
Thanks for posting back.
I have used cutpolya in other objects and those objects
seem to work in AC 9.
I am going to take you up on your offer and send you the object.
This is one of several objects that have the same problem.
Thank you,
Peter Devlin
Frank Beister
Hello Peter,
there are sometimes problems with the enhanced precision in AC9. GS has something changed there in 9. I have a bench, working in 8 and struggles in 9. I know why, but can't fix it. In my case the tube command does not work in this way I used it in 8.
Your object:
The CUTPOLYA is correct. The TUBE too. But working together, they create inconsistence model data. I have worked this out by transfering the parts to a new object, I sent to you. It's very useful, that the poly based commands are very similar. So you can change a CUTPOLYA very fast to a prism_ to see if the coordinates work.
I have replaced the TUBE-command to a block (by PRISM) to get the script run. I think you have created the tube by polyline or profiler. You should give it a try to script it native by the enhanced status codes (1000 e.a.). Then you can adjust it maybe by RESOL or TOLER.
HTH.
Frank
Hello Frank,
Thank you very much for having a look at my object.
You seem to be saying that it is the interaction of the
TUBE command with any of the three "cutting" commands
that causes a problem in AC 9.
I will definitely check this out by scripting some simple TUBE
commands and see if I can cut them with one or all of the
"cutting" commands.
The TUBE command I used in my script was made by Profiler
and the code was copied and pasted into my script.
As far as my object is concerned, I want to ease the outside
edge of the deck flange so I will probably try HPRISM_
and see if AC 9 has a problem cutting that.
Come to think of it, HPRISM_ has the edge hiding capabilities
of PRISM_ so I don't have to cut out the middle of it anyway.
Again, thank you very much Frank.
As usual, you have helped me understand GDL.
I believe it was you who, 6 or 7 years ago, explained to me
why I could not write something like,
if X then Y=something AND Z=something.
It is the "logical" AND.
Peter Devlin
Frank Beister
Peter, HPRISM_ seems to be a good idea. I think it is a special constellation of TUBE and CUTPOLYA in your case. Deleting the TUBE or the CUTPOLYA made the error gone. In the fixed object I replaced the TUBE just with a PRISM_ and it worked (without rounded flange).
I remember the IF-THEN question, but neither that it was you, who asked for, nor it is so long ago. 😉
