CUTPOLYA problem
JGoode
for some reason this bit of script isn't cutting around the middle section and it is just cutting the complete area.
CUTPOLYa 11, 1, 0,
                  -5,           -5,      15,
                   5,           -5,      15,
                   5,            5,      15,
                  -5,            5,      15,
                  -5,           -5,     -1,
                 posx3,          posy3,      1,
        posx2,          posy2,      1,
        posx1, posx1,      1,
                posx5, posy5,      1,
                 posx4,          posy4, 1,
                 posx3,          posy3, -1
Any idea?
ArchiCAD 23
Windows 10
1 REPLY 1
There is no need to mark your posts as solved (the green tick) until you get an answer that does solve it.
I have removed the tick for now (I have also done that for some of you other posts).
The CUTPOLY is not a polygon with a hole, it is just the hole.
So the first 5 lines can be deleted.
Then you define you elements.
Then end the cut.
It goes like this.
CUTPOLY
Element script (i.e. PRISM with those first five co-ordinates
CUTEND
Now you can mark this post as ‘solved’ if you understand what I mean.
