CUTPOLYA tube cutting
Hi there,
I want to cut a tube out of a solid using the CUTPOLYA command.
I cant figure out the syntax. Can someone help me please?
4 Replies 4
Frank Beister
It is in German, but have a look at the syntax on the top and the parameters in the pictures on the right:
www.selfgdl.de/3d_elemente/schnittbefehle/CUTPOLYA/kompendium.php
Sorry, I meant tube as in a round cylinder. that example is a triangle.
Frank Beister
You can do by the mask-part of the path.
CUTPOLYA 2, 0, distance,
xm,ym, 900+mask,
radius,360,4000+mask,
rx,ry,rz
Yes that one worked!
Thank you very much!
