Find the perfect object, manage libraries, create custom objects
Cabinet objects in 3D
I just updated to ArchiCAD 9 from 8.1 and some of the cabinet objects have stray hinge lines that show up in 3D, also the knob is not showing up in the right place.
How do I fix this?
[/img]
18 REPLIES 18
Dwight
are you using ArchiCAD 9 objects?
Dwight Atkinson
The D3 SmartPart cabinet objects had this problem, which has been fixed now, I believe. (At least for the V9 version.) You'll need to get these updated library parts.
Richard
AC26 (since AC6.0), Win10
the objects are that i am trying to load are ArchiCAD 8.1 objects
Dwight
There you go.
As GDL evolves, older elements will not work appropriately, especially as the developers bring higher functions to their objects.
Dwight Atkinson
so what can I do about it?
Dwight
If these are ArchiCAD -sourced, go in the library and find the new cabinet objects. Go into your project file, select each old cabinet type in turn and then, while it remains selected, open the dialog window and transfer its values to the ArchiCAD 9 element equivalent by changing the element to the new one.
Dwight Atkinson
Does anyone know if ArchiCAD has the capability to produce a Printable Inventory of our Libraries, i.e. a catalogue of sorts...?
-kc
Djordje
C:\Program Files\Graphisoft\ArchiCAD 9\Graphisoft Documentation\Library Preview.PDF
Also, try Special menu, Place all objects
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Just checked mine and all that is the Documentation folder is the MSA libaries. No PDF of the AC9 library.
