2024-09-12 06:58 PM - edited 2024-09-12 07:17 PM
Hi! how do I remove these lines ? It is already painful that archicad cabinetry library is not customizable enough for designers so I had to create 3 cabinets instead just ONE with different segments and types... Finally I build the 3 cabinets (already a painful experience) , now these lines shows everywhere! I turned off everything in setting and it is still there. there are connected perfectly and have same finish, so it should hide the lines.... I tried also different display orders but nope, nothing works.
- Floor plan shows ok, all seamless, the cabinet edge visibility on side is turned on for a reason and must stay however the other side is turned off and should not show anywhere and especially not in countertop and baseboard.. I mean... I would have to literally explain the carpenter, piece by piece please don't make cuts, it's my software... and no not a free one.
- regarding floor plan, note worth saying, that countertop visibility also does not show, neither backsplash is ... also can't see each line to be customized for one or another (cabinetry/drawers openings, backsplash, carsas...)
@archicad better come with some *real* updates for interior designers and intuitive work based on feedbacks received for years, because I won't be renewing if I have to spend many hours with workarounds taking hours to find , learn or just simply don't work
Friday - last edited Friday
On windows 11 using Australian libraries....
when placing cabinets side by side so the sides touch....
In Archicad 25 using the Archicad 25 library; the benchtop, kicker and back splash back automatically join.
In Archicad 27 using the Archicad 25 Library; the benchtop, kicker and back splash back automatically join.
but in Archicad 27 using the Archicad 27 library; the benchtop and back splash back automatically join, the kicker doesn't join anymore.
the only change I found was this bit of code;
So somebody did a booboo somewhere....
P.S.
The fix is to add the line elimination mask to the cprism_{3}.
you will need to unpack the library, open the "KitchenLegMacro"
change to mask from "0" to "1+2+4" (technically its just a side connection, so just the 4 should work)
repack the library,
and bingo
it is fixed.
P.P.S.
I found it by opening the cabinet object,
that lead me to the KitchenGeneralMacro,
that lead me to the KitchenFootingMacro,
that lead me to the KitchenLegMacro.
For Archicad 28/29, I haven't checked yet....
Friday
And we worked in Archicad 28 and now 29, and still not fixed.
I think I mentioned this way before, Archicad is just going differences route , which is not interior designers route, if any smaller company. :((
I even checked their roadmap. It’s just looks so out of touch. boooboo
yesterday
With the CI cabinets tool, you could create a support ticket with Central Innovations and they might be able to help out with this problem ?
