Cadimage roof covering - tiled ridges
Thinus
Good day
How do I get rid of the spaces between the ridge tiles and the roof tiles with Cadimage roof coverings tool? Any tips will be appreciated immensely!
Thank you very much for this information! Appreciated.
4 REPLIES 4
While you wait for a possible answer here, you should also contact Central Innovation.
If you do get the answer from them, please post back here also.
Thank you, I shall do that!
Regards
MASz
I ran into the same issue and have already requested a fix from Central Innovation. It's a wishlist item at the moment.
AC28 AUS, Windows 11, i9 14900K, RTX5090, 128GB DDR5, 4k144 display
Setup info provided by author
