How come when I make an object then check the script I get errors when an object (that is a basic AC object) is called I get errors. For example:
I'm making a newel post. It consists of a column, a slab and a pyramid (Pyramid 11)
Simple object, right?
When I "check script" I get errors that:
DIST_Y isn't a valid parameter name
DIST_X isnt' a valid parameter name
GAMMA isn't a valid parameter name
etc., etc.
It seems all the called parameters are invalid. I don't get why this is when it's an AC object.
Here is the whole script:
! Name : StdNewell.gsm
! Date : Wednesday, April 8, 2009
! Version : 11.00
! Written by ArchiCAD
mulx A/0'-6.5000"
muly B/0'-6.5000"
mulz ZZYZX/3'-6.0000"
addx 0'-3.2500"
addy 0'-3.2500"
rotz 270
body -1
model solid
resol 36
GLOB_SCRIPT_TYPE = 3
GLOB_CONTEXT = 3
GLOB_SCALE = 48
GLOB_NORTH_DIR = 90
GLOB_DRAWING_BGD_PEN = 91
GLOB_FRAME_NR = -1
GLOB_EYEPOS_X = 40'-10.5550"
GLOB_EYEPOS_Y = -55'-1.0332"
GLOB_EYEPOS_Z = 25'-0.0000"
GLOB_TARGPOS_X = 40'-10.5550"
GLOB_TARGPOS_Y = 24'-10.9668"
GLOB_TARGPOS_Z = 5'-0.0000"
GLOB_SUN_AZIMUTH = 332.3090550957
GLOB_SUN_ALTITUDE = 56.42999939507
body -1
body -1
GLOB_HSTORY_HEIGHT = 10'-0.0000"
!!Object-01
WALL_ID = "Wall-02"
WALL_INTGUID = "00000000-0000-0000-0000-000000000000"
WALL_RESOL = 36
WALL_THICKNESS = 0'-9.0000"
WALL_START_THICKNESS = 0'-9.0000"
WALL_END_THICKNESS = 0'-9.1250"
WALL_HEIGHT = 10'-0.0000"
WALL_LINETYPE = 1
WALL_FILL = 85
WALL_FILL_PEN = 2
WALL_SECT_PEN = 1
WALL_VIEW_PEN = 11
WALL_FBGD_PEN = -1
WALL_POSITION[1] = 0'-0.0000"
WALL_POSITION[2] = 0'-0.0000"
WALL_POSITION[3] = 0'-0.0000"
WALL_MAT_A = 68
WALL_MAT_B = 50
WALL_MAT_EDGE = 50
GLOB_ELEVATION = 3'-3.0000"
SYMB_LINETYPE = 1
SYMB_FILL = 85
SYMB_FILL_PEN = 91
SYMB_FBGD_PEN = -1
SYMB_SECT_PEN = 4
SYMB_VIEW_PEN = 4
SYMB_MAT = 18
SYMB_POS_Z = 3'-3.0000"
SYMB_ROTANGLE = 225
SYMB_A_SIZE = 0'-9.1875"
SYMB_B_SIZE = 0'-6.4965"
GLOB_CUTPLANES_INFO[1] = 4'-0.0000"
GLOB_CUTPLANES_INFO[2] = 10'-0.0000"
GLOB_CUTPLANES_INFO[3] = 0'-0.0000"
GLOB_CUTPLANES_INFO[4] = 0'-0.0000"
WALL_THICKNESS = 0'-0.0000"
pen 4
set material "09 | Paint-02 Whitewash"
GLOB_LAYER = "A-FLOR"
GLOB_ID = "Object-01"
GLOB_INTGUID = "634A70BD-A518-DC4E-9D98-C3C287CDD14A"
GLOB_ELEM_TYPE = 1
body -1
add 0'-0.0000", 0'-0.0000", 3'-3.0000"
rotz 225
call "Pyramid 11",
PARAMETERS A = 0'-9.1875", B = 0'-6.4965", ZZYZX = 0'-3.0000",
AC_show2DHotspotsIn3D = 0, gs_detlevel_3D = "Detailed",
radius_1 = 0'-4.5937", edit_mode = "Angle-Length", end_mode = "Perpendicular",
edge_num = 4, gamma = 90, length = 0'-3.0000",
dist_x = 0'-0.0000", dist_y = 0'-0.0000", gs_shadow = 1,
gs_cont_pen = 4, gs_fill_type = ind(fill,"Empty Fill"),
gs_fill_pen = 2, gs_back_pen = -1, gs_prim_mat = ind(material,"05 | Copper New"),
gs_list_cost = 0, gs_list_manufacturer = "", gs_list_note = "",
gs_list_location = "", gs_list_accessories = "", FM_Type = "Others",
FM_InventoryNumber = "", FM_SerialNumber = "", FM_ProductionYear = "",
FM_ObjectWeight = 0, FM_ObjectWeightUnit = "kg",
gs_list_custom1 = "", gs_list_custom2 = "", gs_list_custom3 = "",
gs_list_custom4 = "", gs_list_custom5 = ""
del 2
body -1
!!Column-01
pen 2
GLOB_ID = "Column-01"
GLOB_INTGUID = "A7A89F5F-607A-D94E-82C3-CBD044781E9E"
body -1
sprism_{2} col_mat, col_mat, col_mat,
5, 0'-0.0000", 0'-0.0000", 3'-3.3701", 0'-0.0000", 3'-1.5000", 0,
0'-0.0000", 0'-0.0000", 3'-3.3701", 0'-0.0000", 0'-0.0000", 0,
-0'-2.7500", -0'-2.7500", 63, ind(material,"09 | Paint-02 Whitewash"),
0'-2.7500", 0'-2.7500", 63, ind(material,"09 | Paint-02 Whitewash"),
-0'-2.7500", 0'-2.7500", 63, ind(material,"09 | Paint-02 Whitewash"),
body -1
body -1
!!Slab-01
GLOB_ID = "Slab-01"
GLOB_INTGUID = "92445F34-0C9F-1A4B-A761-DF3DA9FB1D17"
body -1
addz 3'-1.5000"
cprism_ "09 | Paint-02 Whitewash", "09 | Paint-02 Whitewash", "09 | Paint-02 Whitewash",
5, 0'-1.5000",
-0'-3.2500", 0'-3.2500", 15,
0'-3.2500", -0'-3.2500", 15,
-0'-3.2500", -0'-3.2500", 15,
-0'-3.2500", 0'-3.2500", -1
base
vert 0'-0.0000", 0'-0.0000", -3'-1.5000"
vert 0'-6.5000", 0'-0.0000", -3'-1.5000"
vert 0'-0.0000", 0'-6.5000", -3'-1.5000"
vert 0'-0.0000", 0'-0.0000", -3'-0.0000"
coor 8468, -1, -2, -3, -4
del 1
body -1
