Can I use .3DS file for ArchiCAD
I try to use some model for current project. Someone told me that I can also use .3DS file. How do you put .3DS file into the library manager?
AFAIK: The only way to get 3ds into the library is with an add-on that only works in ArchiCAD 7.0. It is called 3ds_in. It can be found in the Goodies folder (as I recall) and needs to be moved to: >Applications>ArchiCAD 7.0> Add-Ons>Import-Export
Once loaded, it is accessible in a menu which I think is called "Extras". I don't remember for sure and I don't have AC7 loaded right now.
This functionality should be available as a standard feature in File > GDL Objects > Open Object... Is this already in the wish list? If not, it should be. Even better would be drag and drop 3ds parts straight from the web.
Thank you! the ArchiCAD that I use in my intern is 7.0. Thank you for your help :lol:
