I've downloaded an object from archibaseplanet.com and tried to test it out on archicad. I added this object to the library but it doesn't appear when I try to select and place it. Can someone tell me how to do it? I must been doing something wrong I guess...
I just dragged and dropped the .GSM file into 21 and it works fine (except for the materials).
When you select the object tool, make sure you browse to the 'Embedded' library and then look on the folder called 'Object' (as you have it set up).
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
1. Is the Library part in GSM file format?
2. Is the Library part located in a Loaded Library? You can check your Loaded Libraries in the Library Manager Dialog.
3. What type of Library Part is it? Because it depend on which Tool will be able to place it. Doors can be placed with the Door Tool ,Windows with the Window Tool, Lamps with the Lamp Tool, most other Library parts with the Object Tool.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
Also what Archicad version are you using?
You may have downloaded a version 21 object and you are trying to use it in version 20.
You won't be able to use objects created in a version newer than the one you are using.
I'm not quite sure about 2nd question since I don't have an english version and I don't really know where to find "library manager dialog", so I'll just post my library manager (it's in polish but I think you'll get the idea)
Also notice that folder I've created doesn't even appear in object options.
