Can't create textblock with string from REQUEST(...
Hello!
My code:
REQUEST ("Zone_category", "", catname, code)
TEXTBLOCK "MY_TEXTBLOCK_1" 0, 5, 0, 1, 1, 0, catname
I get the error "requires an expression of type string"
But:
catname = "tmp_cat_name"
work without errors.
How I can get category name and create textblock with it?
Help me, please!)
7 Replies 7
Jochen Suehlo
Maybe this is a bug in ArchiCAD. I dont't know.
But this works, if you want to use TEXT2:
x = REQUEST ("Zone_category", "", catname, code)
TEXT2 0, 0, catname
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Maybe at first before request:
catname = ""
guessing...had something similar lately.
Best Regards,
Piotr
I tried:
catname = ""
gives an error too (
Tsepov wrote:
I tried:
catname = ""
It should work normally.
I do not think that you accidentally forgot about the paragraph, but here is the complete code (simplified, without coefficients) just in case.
Catname = ""
Catcode = ""
	QW= REQUEST("Zone_Category", "", Catname, Catcode)
PARAGRAPH "NAMECAT" 2, 0, 0, 0, 1
	""+Catname
	ENDPARAGRAPH
TEXTBLOCK "CAT" 0, 5, 0, 1, 1,1,"NAMECAT"
RICHTEXT2  0, 1, "CAT"
I find with REQUEST you always have to say xxx = REQUEST...
This is because it returns a value to xxx if the request is successful or not.
As well as returning the actual values you were requesting in the first place.
Its work!
Catname = ""
Catcode = ""
""+Catname
ENDPARAGRAPH
SL_GDL, many thanks for the help!
to avoid errors with str var type after REQUEST it is better to do so:
IF QW <> 0 THEN ! if answeres more then 0
Catname_ = Catname
ELSE
Catname_ = ""
ENDIF
Catname_
ENDPARAGRAPH
