Can't make a line dashed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-04-12 02:15 AM
Any advice on troubleshooting that a line refuses to be set to dashed. Hitting the 'Line Selection Setting' and selecting the desired dash doesn't change it. Tried toggling through 'uniform..' , 'drafting line', "cut" and not cut.
Tried repair the file, nothing.
Tried different pens, nothing.
UGH!
Maybe something got toggled in a general setting somewhere causing this, but if so, can't find it anywhere.
Appreciate your time if any suggestions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 02:42 AM
There was a bug where you couldn't select different line types (which I believe has been fixed).
But it sounds like you can select the line type you want.
I would guess that you have a Graphic Override or Renovation Filter that is overriding the line type.
So no matter what you set it to, it is still getting overridden as something else.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 02:53 AM
Thank you for your message --much appreciated. Actually, no, I can't select the line type I want. I can't switch a solid line to any dashed line.
Checking my graphic overrides, and none are set to solid.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 02:57 AM
If you can't select the different line types, you can use the arrow keys to move up/down in the list.
Or apply the latest update - I think that is supposed to fix it (I am assuming you are using version 26 - you should ideally add some information to your signature or at least tell us what you are using - Archicad version and operating system).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 03:09 AM
Ok, ugh, so using arrows up and down is the only way to select and not by clicking on the desired dash with the mouse?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 03:14 AM
It is a known bug in 26 in Ventura, that has supposedly been fixed with the latest update.
I can't confirm as I don't have a Mac.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-12 03:22 AM
Yes, mine is Ventura on Mac, thanks. Again, much appreciated!
