‎2015-01-21 07:31 PM
‎2015-01-21 07:33 PM
‎2015-01-21 07:56 PM
‎2015-01-21 08:35 PM
‎2015-01-21 09:24 PM
Erika wrote:
When you 'Add' in the library manager choose the option to 'Link Library' rather than 'Browse for Embedded Objects'.
Are you opening a 17 filein 18? If so you should have had a pop-up asking you which of the following you wanted to do:
1. Chose to load the 18 library and then load the 'Migration libraries'. This will auto-convert many of the 17 library parts to 18. The migration libraries should cover the remaining non-18 parts.
2. Or, you can open the file in 18 and choose to load the 17 library instead of the 18 one.
If none of the above, post a screenshot of your library manager so we can see what is happening.
‎2015-01-21 09:56 PM
