Can windows read zone areas
Can a window object determine the area of a zone that it has been placed into?
I know it can determine the zone name, number, category and code from REQUEST("Zone_relations",...)
But can it tell what the area of that zone is directly from the zone.
I know it can be done by having the zones save their info to an external text file and then have the windows read that info in but I want to avoid the text files if possible.
Does anyone have any ideas?
6 Replies 6
Cosminn
Hello Barry, any luck with this? I am almost in the same situation.
Thank you
Sincerely,
Daniel
No as far as I know there is no way to get area directly from the zone.
The zone stamp has to save out to a text file and then any other object can read from the text file.
But I never got around to doing it.
alemanda
In general, it would be quite useful having the chance to specify somehow the topology of an element. I think of BOQ referencing purpose ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Cosminn
Thank you guys for your reply.
Other question I have, It's possible, a stamp to read the over all width and depth of a room?
Please see attached screenshot.
Thank you
Sincerely,
Daniel
alemanda
I think it is possible ... only a little bit hard to code properly to get what you want ...
AC27 latest hotfix
Win 11 Pro 64bit
Cosminn
Thank you for your prompt reply alemanda.
Any suggestion for a start point?
I tried to get room dimensions using objects who are attached to zones, via Interior Wizard add on and I was able to obtain the over all width and depth for a rectangular and square room. As you said for a custom room geometry you need the right code for that and I am still working on that.
Any advice will be greatly appreciated.
Thank you,
Daniel
Sincerely,
Daniel
