Can you place an infield over a picture within the interface
JGoode
I was wondering if it is possible to place an infield over a picture in the interface?
thanks
ArchiCAD 27
Windows 10
5 REPLIES 5
Better split the image...
Best Regards,
Piotr
I found a work around many years ago.
The trick is to script the UI_INFEILD.
Then script the UI_PICTURE.
Then script the UI_INFEILD again with exactly the same values.
So here is an example form one of my window objects ...
UI_INFIELD "side_hgt_rake", 0,120,40,15
UI_INFIELD "side_hgt_above_beam", 20,55,35,15
UI_PICT "coastalview freeform dr-win.jpg", 0,10, 440, 216, 1
runxel
Hero
Whats the goal here?
Could you post a picture, Barry?
Something like this where all the infields overlap a background image.
If you only have the infields before the picture you wont see them but can edit them if you know where they are.
And if only after the picture you can see them but can't edit them.
Before and after allows you to edit them and see them.
runxel
Hero
Thanks a lot Barry!
That makes it clear. 🙂
It's a very nice (but sadly needed) "hack" btw.
