Can you remove Graphisoft parameters?
JGoode
Having a bit of trouble with sub-types and was wondering if there is any way at all to remove the parameters that get added in?
Thanks
ArchiCAD 23
Windows 10
You will get different parameters depending on the sub-type you select.
You can't delete the blue (Graphisoft) ones but you can hide them by turning on the 'Hide' button and you can move them to the bottom of the list.
JGoode
That's what I thought but I didn't know if there was some sort of workaround. Thanks for the reply.
ArchiCAD 23
Windows 10
