Changing direction of L-Shape stair
Hello can anybody tell me how you can change the direction of an L-Shape stair please?
4 REPLIES 4
Version of AC? Library part (pre-built L-stair) or custom one made with Stairmaker? Or with another add-on?
It is Archicad 15, and just a custom stair L shape from the library
Thanks. If it is from the library, then it is not custom. 😉 A custom stair is created via the "Create Stair" button at the top right of the Stair Settings dialog. Assume you are using "Stair L-Shape 15"...
Anyway, just mirror it. Click the mirror button as shown in the attached. Or, select the placed stair and issue the mirror command (either pet palette, Edit menu, or shortcut - ctrl-M) and give the mirroring axis.
Thank you very much for the help
