Andrew Swenson
Changing strings to numerical values
I am trying to use the Global ID to input the starting number of a counter I have in a carpark object. So that I don't have to open up the object settings everytime I want to change the start number.
I understand that the Global ID is a string but I need to have a numeric value to use as a counter.
Is there a way of changing the Global ID value from a string type to a numeric type?
ArchiCAD 5.1 - 24
MSI WS63 8SL
Intel i7-8850K @ 2.60GHz
32Gb RAM
Windows 10 Pro 64bit
TwinMotion 2020.2
3 Replies 3
Frank Beister
So I have done in mine.
You have to use the SPLIT command:
FLAG=request("ID_of_main","",NRT)
FLAG=split(NRT,"%n",NR)
if strlen(NRT)>strlen(str("%.0",NR)) then FLAG=0
FLAG is a boolean, returning, if the GLOB_ID is an integer>0 or not. NR contains the number.
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
Andrew Swenson
Thanks I will give it a try.
ArchiCAD 5.1 - 24
MSI WS63 8SL
32Gb RAM
TwinMotion 2020.2
Andrew Swenson
Well that worked! Thanks for the help.
ArchiCAD 5.1 - 24
MSI WS63 8SL
32Gb RAM
TwinMotion 2020.2
