Cigraph Problem
Joseph wrote:
CadImage products are very useful but have had problem with above issues, bugs in there products and not a good tech support.
Cigraph's customer service isn't exactly stellar, either. I've been trying to get my ArchiStair upgraded for almost *three weeks* now, utterly without success.
Their website is down half the time I try to log on, so I couldn't order the upgrade through them and get the serial number right away (or what I had at least hoped would be right away). Objects Online has to jump through their hoops before they will issue a serial number also.
And God help you if, like me, you find yourself having to replace your hardware key, because your Cigraph add-ons will stop working, and you will not be able to upgrade them without a major hassle.
Almost 3 weeks ago, Fabrizio told me he would reset my serial number since I couldn't find it when he got a message from my reseller showing the hardware key had been replaced, so I forwarded him the message from Graphisoft documenting it had been sent.
So, did I get the reset number? No. Fabrizio claimed he never got the forwarded email. And even after resending it, he *still* didn't reset the unlock code, or whatever the hell they call it. When I wrote him to remind him the other day, all he did was tell me to download the demo, that I didn't need the old registration ID for that!
As if that solves my problem - particularly since the demo version only allows you to do 10 commands.
Not 10 staircases, mind you, or 10 days' worth of use - but 10 *commands* - including modifying existing staircases. So, if you're novice at this program like I am, you may not get very far on even *one* staircase, if you need to make modifications after you first create it.
So, once you even figure out how to load the damned thing in the first place, which is the world's worst pain in the ass to actually get it working, you *still* find yourself with just a demo version despite having purchased the software.
I am so pissed right now I could just spit.
Wendy
17 REPLIES 17
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear Wendy,
I'm really sad saying you are so angry with us that you had the need to insert once again this post in a different place...
I hope I won't offend you if I post here the same answer...
Dear Wendy,
for sure when an user has a trouble the fault is us… in any way, also because in the better case there has been a lack of communication between us and the final user.
Starting from this point let me summarize what is happened (at least from our side).
You contacted me by saying you downloaded the ArchiStair update but that it was running as demo version (11/7/2006 is your first e-mail to me… 10 days ago and not *three weeks*! If the matter started before I can only address the trouble the user notify us so… 10 days ago).
The reason because ArchiStair was not working is that the compatibility updates for ArchiCAD 10 are not free of charge.
Also in this site I posted this new, all the Distributors know about it and… I don’t know how we can better inform the user about this.
BTW, your first e-mail subject was “ArchiStair for Archicad v10” so it was clear for me (probably this was my fault) that you was asking for the version for ArchiCAD 10.
In the same day you wrote me another e-mail (the third one because you addressed my first reply, where I explained you should buy the compatibility update, saying I was right…) saying you bought the compatibility update from Objects Online (that means OOL sent you the new Registration ID needed to get the new unlock code) but that you wasn’t able to download the software.
In this last period our web site is under maintenance but here started the “mystery” for me: in the first e-mail you told you was not able to use ArchiStair under AC 10… just the Registration ID was missing so… why did you need to download the software once again?
Never mind.
You wrote “Objects Online has to jump through their hoops before they will issue a serial number”: quite simple the reason, to provide the user or the Distributor with one of this Registration ID we need the previous Registration ID!
The compatibility update costs just 15 Euro so we have to be sure we are selling ArchiStair for AC 10 to an existing user… otherwise anybody could get the software for 15 Euro instead of 86 Euro!
“And God help you if, like me, you find yourself having to replace your hardware key, because your Cigraph add-ons will stop working, and you will not be able to upgrade them without a major hassle. “
What I need to reset a Registration ID when an user change the dongle is, quite simply, the Registration ID itself! If the user don’t have anymore the Registration ID I cannot reset it.
Please, try to imagine to ask Graphisoft to substitute a dongle you don’t have anymore: just the same!
BTW, I never received any communication from anybody saying you got substituted your AC dongle.
You wrote “Almost 3 weeks ago, Fabrizio told me he would reset my serial number since I couldn't find it when he got a message from my reseller showing the hardware key had been replaced, so I forwarded him the message from Graphisoft documenting it had been sent.
First: unfortunately I never received your e-mail regarding the dongle substitution.
Second: once again, not three weeks but 10 days ago
Third: how can explain you that I cannot reset a Registration ID if you don’t tell me your Registration ID?
“When I wrote him to remind him the other day, all he did was tell me to download the demo, that I didn't need the old registration ID for that!”
To download the software you DO NOT need anything!
At that point you had the Registration ID (bought from OOL), you had the software (I just suggested you to download it once again) so… what was the trouble?
“Not 10 staircases, mind you, or 10 days' worth of use - but 10 *commands* - including modifying existing staircases.”
BTW ArchiStair when run in demo version let you do less than this: you can only browse the dialog windows nothing else!
When you use ArchiCAD Demo version you can do a lot of things but you cannot save the project so…
Just as happy end today you wrote me you finally found your Registration ID, both the new one (that one sold by OOL) and the previous one.
I just reset the old one (sorry for the late but I have before to reply to your post here!): as usual, as the user send me the Registration ID I immediately reset it… without it I cannot reset anything!
What is still a mystery… sorry again for my stupidity… is that I checked on our webserver database the status of the new Registration ID (that one you bought from OOL and that you need to use ArchiStair under ArchiCAD 10) and… YOU STILL DIDN’T USE IT!!!!
So, please, could you be so kind to explain me how can I help you?
Friendly (really!)
Your
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Andy Thomson
This is a genuine problem - when overzealous copy protection 'impedes fair use'. It is the primary reason we have never purchased such third party add-ons, despite the fact that they are very good, in fact, I consider archistair and door/window builder absolutely indispensible, but hugely problemmatic from a cad/project/library management perspective.
It has been suggested that these vendor/developers tie their licensing to the workstation, such as Artlantis does, which can easily be 'deactivated' from one machine and 'reactivated' on another machine.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
The idea could be very good but... too much expensive for a so cheap software (86 Euro).
On the other hand you could simply switch the dongle from a computer to another one or (this just because we addressed a very similar request from another user) just keep these tools on a dedicated machine where you will elaborate all the things related to these add-ons and simply load the add-ons library on the other computers which wil be able to use these elements (display but not edit).
Just an example for ArchiStair: on the dedicated computer you can create and edit the stair on all the other ones you will see those stairs.
Of course if you have a net dongle all these trouble disappear...
Friendly
Fabrizio
Fabrizio Diodati
Rakela Raul
all the above trouble for this "cheap addon" ?? something is wrong here !!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
someone could be so kind to make a list of all this large amount of above trouble?
Fabrizio Diodati
Andy Thomson
My sentiments exactly. Fabrizio, it is not just about a single add-on, but all the related software, and the sum total of add-ons, cadimage, maxon form, etc. required to work productively - managing all of these becomes unfortunately a major pain. I WANT to use ArchiStair, but I seem unable to convince you that the licensing is a problem.
I don't have an easy answer, apart from allowing Graphisoft to purchase ArchiStair - then, obviously, I would use it all day long 😉
Director
TomWaltz
It was this exact problem that stopped me from using Cigraph products. When Archistair was free, the hassle of installing it was more than the hassle of using StairMaker (until I wrote my own stair one day just to see how hard it was.... and it was really hard!!)
Tom Waltz
Can we go Object Base ArchiStair? I think this will solve a part of problem of not having the Stair as an object when thing go wrong.
Joseph
This is also why I have difficulty recommending add-ons to my clients. The management overhead is too much. I have one client right now that I am helping to develop all the parts they need in-house (including stairs and railings) since this will end up less expensive in the long run.
Yes Tom, stairs are hard when all you have is plain old GDL. I've been kicking this one around for a long time. I'm glad to finally have the chance to finish one.
Every so often I am reminded of my work on speedikon. This is one of those times. They had a stair macro environment that was really pretty good. Despite having to write code in a text editor, batch process it in a DOS based compiler (strange for something originating in UNIX), and then load it into Microstation/speedikon (aka speedikon-M) to see the results, it was still easier than writing a stair in GDL.
