2020-02-27
02:12 AM
2023-05-24
12:25 PM
Rubia Torres
2020-02-27 02:54 AM
MATERIAL gs_frame_mat frame code... MATERIAL gs_leaf_mat leaf code... MATERIAL gs_leaf_mat sash code... MATERIAL gs_glass_mat glazing code...
2020-02-27 03:13 AM
Lingwisyer wrote:
Though a poor solution, you could try modifying the object.
Ideally the code is something along the lines of,
If it is, then you could just change theSet Materialfor the sash. If not, you would have to isolate the sash code and insert a new Set Material.
Ling.
2020-02-27 05:59 AM
2020-02-27 01:26 PM
2020-02-27 05:45 PM
Jp1138 wrote:
I don´t know if I´m not understanding the problem correctly, but I don´t seem to have that problem in the Spanish version.
I don´t understand why all libraries don´t have the same functios![]()
2020-02-27 06:04 PM
rm wrote:It´s troubling that basic functions are not consistent. For example, I read here
I think you understand the problem just fine - your image shows what we can't do with the US library but you can do with the Spanish version library! This is inexcusable Graphisoft. Why are the library part settings not consistent market to market?!? If the Spanish version library can set frame, sash, panel finishes separately for interior and exterior, why can't the US library do the same, for that matter ALL AC libraries should do the same.
This just clearly illustrates how little attention the libraries get, at least in the US!
Fix this PLEASE GS!
2020-02-28 03:47 AM
