Ilder,
If it was only one or two objects that were going to be used on 20-30 projects I'd probably build the GDL from scratch as I would be able to control the clarity of the coding. Morph editing takes a fair bit of time as well but occasionally has it's place.
With the current project there are over 750 independent GDL objects. The objects are only going to be used on a hand full of projects so rebuilding even a portion of them is out of the question.
What I'm looking for is some control over the import process to restrict RESOL of curves. Or failing that an ability to automatically reduce faces in a generated GDL.
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2026
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
