Stair settings/FLR PLN display.
Hello ArchiCAD friends...
I've been using ArchiCAD for about 7 years now and I'e run into a strange problem. In ArchiCAD 19 I have floor/slab height change on the same story (1st story) of about 2'-6"... I tried to put in a stair with 4 risers (6") and treads of 10" (not that that matters) but when the stair is placed it shows 6 risers, numbering 4 as specified before the cut line begins.
So... 1, there shouldn't be a cut line, 2 being the biggest problem, the graphic floor plan display is wrong.
It is not a custom stair, just a library stair with rise/run settings.
Any help would be much appreciated.
Let me know if any other info is needed?
0 Replies 0
