Conversion of 3-D AutoCAD object to Archicad
I know there is a way to convert a 3-D object that was created in Autocad into a library part for ArchiCAD I just cant remember how.
I have a very extensive collection of .dwg models of everything from Aircraft to tanks and I would like to use them in ArchiCAD but I am having trouble figuring out a way to translate them in 3-D.
8 Replies 8
Hello,
File... -> Libraries and objects... -> Open object... (type DWG)
Hope this helps.
Best Regards, Juha
Hi Chris,
I'm fairly sure this is a AC12 only procedure unfortunately. (I can't see AC12 in your signature.)
See here -
http://www.archicadwiki.com/Open%20DWG%20containing%203D%20data?highlight=%28%5C%E2%80%A2%5C+ArchiCAD%5C+12%29
This may help? -
http://www.archicadwiki.com/TechNotes/Importing%20AutoCAD%20Solid%20Objects%20to%20ArchiCAD?highlight=%28dwg%29
I'm confused Peter ... which part did you think was AC 12 only? You can open dwg as object since at least 6.5 AFAIK.
Karl
My apologies, I thought that 3d dwg was natively saved in ACIS format that only AC12 could read. Reading the reference guide again, it is clearly not. I'm getting confused
I will shut up now! Sorry!
Peter wrote:
I will shut up now!
Please don't! 😉
Karl
Thank you all this was most helpful. I might be submitting the converted parts to the Depository as I convert them and add parameters to the GDL Scripting once they are converted to library parts.
That is when I have time to do it.
Thanks in advance for doing that.
If there can be one suggestion: make sure to clean up the 2D Symbol of the created GDL, you can use the Line Consolidation Tool for this fairly well.
Erika Epstein
off-topic somewhat, Chris, do you really live in the San Diego Zoo and Wild Animal Park? That's one of my favorite places!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
