Converting AC10 objects to AC11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-06-24
09:47 PM
2023-05-24
12:42 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-25 06:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-25 10:25 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-25 10:54 PM
The only other thing I can think of is missing layers. Have you opened an AC10 file in AC11, or are you merging an AC10 file into AC11?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-26 02:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-26 03:04 PM
New parameters are created to take advantage of new features, so keeping the old libraries is often an undesirable option. For example, going from AC10 to AC11 broke a lot of section/elevation marker links if you kept the AC10 library.
You can count on having to recreate favorites if you upgrade from one version to another. Even if you use "visual favorites", you still have some maintenance to do with new releases.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-26 06:36 PM
TomWaltz wrote:Huh -- ours transferred just fine (with the AC10 Subset Library loaded).
In my experience, object favorites don't transfer from version to version. The libraries change too much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-26 11:49 PM
Laura wrote:Are you loading the AC10 subset into all your new AC11 projects? If so, will you continue to do so in AC12? (presumably loading AC10 and AC11 subsets?)TomWaltz wrote:Huh -- ours transferred just fine (with the AC10 Subset Library loaded).
Sooner or later you might want to cut the cord to old versions. Subset libraries work pretty well when upgrading a project from one version to the next, but not when upgrading an entire office and starting new projects in new versions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-27 12:07 AM
What I like about the Subset Library is I can place outdated custom parts there, and introduce new and improved parts in our office library without messing up projects that are well underway.
