Want to turn off Fill of Library Trees in plan
I would like to turn off the fill of the library trees in plan so that I can see just the outline. I want to see the design of the planting design and architecture below.
How is this done?
I did a search but didn't see anything. I might have been searching for the wrong thing?
I'm working in 10. I will be changing my signature to show all this.
You should be able to adjust the Model View Settings to achieve what your after. Set the fills to "Contours Only" - these setting can be saved with your views.
Make the background fill of the trees colour 0.
