Converting stairmaker objects from Ver 11 or older
I'm working on a drawing (someone else's) which started life in Ver 11 (or possibly before that) and has been saved under Ver 12.
All the stairs show up as blobs, but when I try to reload the gsm files from the project file, these are grayed-out (presumably because they were created under an older version).
Is there a way to fix this, or do I have to reconfigure the stairs under ver 12?
Keith
Archicad Ver 12 on Mac OSX 10.4.8
10 REPLIES 10
Erika Epstein
Keith,
There have been many discussions about Library management here if you do a search.
This is old, but still applicable.
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue03/libmgnt.html
Essentially you should see
- Archicad Library AC12 [current version] loaded from each computer
- Project library [on the server. Includes custom objects specific to this project only such as stairs. I keep them in their project folder]
-Office Library [on server, includes bought and custom made objects used on multiple projects]
- Libraries needed for this project but not typicall for other projects such as older AC library versions for projects started in earlier ACs. These can be downloaded
here Click on Library Archives
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
