Coordinate system through 3 spatial points
I am new to GDL but i want to know if is possible to create some 3D GDL objects similar to the adaptive components of Revit. I know we can access GDL parameters from Grasshopper so i thought of a simple example. I want to create a triangular panel and control the coordinates of the nodes from Grasshopper. I have used the PLANE command as a try but there is no thickness.
Is there a way to move the coordonate system in 3D to a plane defined by 3
I don`t understand it yet but is XFORM command able to do this?
0 Replies 0
