‎2023-04-25
05:32 AM
‎2023-05-24
09:44 AM
Rubia Torres
Hi there, I am trying to copy a window element from one plan into another plan using AC24 with Mac. (I have two projects open with AC24). When I perform the copy and try to paste into the other plan the copy clipboard is empty ?
I remember doing this very move with my windows machine using AC24 a few months ago but why it’s not working now with Mac has go me stumped.
Anybody know what steps I am missing ?
Solved! Go to Solution.
‎2023-04-25 08:20 AM
You can’t copy windows or doors from one file to another independently of the wall. You need to copy and paste the wall that contains the window or door.
‎2023-04-25 09:02 AM
I will have to remember that from now on and to copy wall segments with either doors or windows in them.
Thank you for your help.
‎2023-04-25 03:49 PM
Copy the wall that the window sits in or just pick up the properties
‎2023-04-26 09:06 AM
The good old teat pipette and inject the parameters treatment. It’s nice to know that it will also work across opened plan instances as well.
‎2023-04-26 09:50 AM
No it doesn't - only works within the current plan.
Only Copy & Paste will do what has been discussed.
‎2023-04-27 04:58 AM
Ok got it, so that will not work across opened plan files.
‎2023-05-10 08:58 PM
Another way is to pick up the parameters from a trace reference
‎2023-05-11 03:25 AM
But not possible from separate files which is what the original poster wanted.
‎2023-05-11 03:41 AM
I didn’t know that we could pick up parameters from a trace reference even if it is in the same plan file. You learn something new every day with this software.
