mthd
Copying elements between two different plans in AC24 on Mac
Hi there, I am trying to copy a window element from one plan into another plan using AC24 with Mac. (I have two projects open with AC24). When I perform the copy and try to paste into the other plan the copy clipboard is empty ?
I remember doing this very move with my windows machine using AC24 a few months ago but why it’s not working now with Mac has go me stumped.
Anybody know what steps I am missing ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
1 Solution
Lee Hankins
You can’t copy windows or doors from one file to another independently of the wall. You need to copy and paste the wall that contains the window or door.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
11 Replies 11
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
mthd
I will have to remember that from now on and to copy wall segments with either doors or windows in them.
Thank you for your help.
Tim Ball
Copy the wall that the window sits in or just pick up the properties
Tim Ball
AC26, iMac
User since V5
mthd
The good old teat pipette and inject the parameters treatment. It’s nice to know that it will also work across opened plan instances as well.
No it doesn't - only works within the current plan.
Only Copy & Paste will do what has been discussed.
mthd
Ok got it, so that will not work across opened plan files.
Tim Ball
Another way is to pick up the parameters from a trace reference
Tim Ball
AC26, iMac
User since V5
But not possible from separate files which is what the original poster wanted.
mthd
I didn’t know that we could pick up parameters from a trace reference even if it is in the same plan file. You learn something new every day with this software.
