Corner Window - Differing Reveal Depth
Lingwisyer
Guru
Hi all,
How do you go about creating a corner window where each of the windows has a different reveal depth? There is no option for it...
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
6 REPLIES 6
Don't use the corner window tool.
Use 2 separate windows and turn on the corner options.
I am not sure if this will work at the corner but you should be able to control the reveal depth separately.
Lingwisyer
Guru
There are only options for corner angle, wall width, column size and offset from corner column...
Might have to start using my corner door Complex Wall Profile for windows as well...
Ling.
Does this work?
I don't use these windows so I am just playing.
Obviously the difference between my reveals was 30mm.
Lingwisyer
Guru
That just changes the windows reveal from the post. I am wanting to retain a square post and have the post reveal to wall face be different.
Ling
Lingwisyer
Guru
New wish here.
