Corner window in archicad
How to make this kind of window in archicad?
3 Replies 3
It depends on what window objects you have.
But with any of the Graphisoft windows you can use them with the corner window tool.
You should then be able to turn corner connection type to 'Glass'.
Thanks for quick reply.
But how to make a door on one side and openable window on other side like shown in the picture.Is this possible in Archicad?
Place separate doors and windows next to the corner windows.
You will then want to look at the ganging options if you want to share frames and casing.
