Srinivas
Creating Templates
Dear All,
With the default settings in Archicad Int 9.0 the doors are always set to scale sensitive under its options. I want this to be DETAILED everytime and also TRIM to be OFF, so I thought of creating a template.
I changed this option to detailed and saved it as a template. But when i open the template, the doors are again set to scale sensitive.
I also opened a new file with last profile and then save the file as a template. But when I opened the template file still the doors option is set to scale sensitive.
Where I am doing a mistake.
Awaiting your response.
Much Thanks,
Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
2 Replies 2
__archiben
library part parameters do not form part of the .PLN settings and therefore cannot be saved with a PLN or TPL file.
you need to save favourites that can be loaded [with the PLN/TPL, or re-save the library parts with different default settings. the latter can only really be justified if you are creating your own, new library parts that are unique from the 'ArchiCAD Library' itself . . .
HTH
~/archiben
b e n _ f r o s t
Please do not double post. This question has now been answered twice.
