Curtain Wall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-02-10
08:36 PM
2023-05-26
12:19 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 04:14 AM
jonathang wrote:Select the panel you want to change and pick the one you want from the pop-up list in the info palette.
How can I edit a curtain wall to have doors...
...and to reduce the number of vertical members between glass?Select any mullions you want to remove and press the delete key. The panels will alter to fill the space. You can also add mullions by dragging copies.
I assume you know that you have to be in edit mode in the 3D window to modify the curtain wall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 06:57 PM
I can now put in the doors and change the curtain wall types, but I am still having difficulty eliminating some of the mullions. I can delete some, but others won't allow me to delete. How can I further edit the curtain wall to have less mullions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 07:09 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 10:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-12 01:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-12 04:55 PM
jonathang wrote:For mullions that don't delete, you can try selecting the mullion, opening its dialog box, and changing its type from Generic to Invisible.
I could understand not being able to delete the perimeter mullions, and making it thin helps to make the door look better,...
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-14 07:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-14 07:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-14 08:45 PM
