Curtain & roller blind GDL object
Anyone know where can get curtain & roller blind GDL object, or can shared with me??
Thanks.
5 REPLIES 5
You can go to www.cadimagetools.com
There are objects to your like
cheers
Djordje
Thanks.
Did you check the Depository?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
there is a good roller blind objet here: objectstop.com/?page_id=27&category=42&product_id=176
Hi Nguyen, Djordje & SDB,
Thanks for the reply.
Djordje, i did check the archicad depository but can't find the curtain or roller blind.
Hazel
I'm pretty sure that there is a roller blind (rolladen) in the German library, but it might be an optional accessory to the windows rather than a separate library part? Might be in other localized versions, too?
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
