Curved arched window
I'm currently modelling a historic building and so I am also modelling the quirks of an old Victorian building. Is there any way to customise a curved window to have an arched top? Seems like It's one or the other at the moment. I'm still running Archicad 21
Hmooslechner
You can make any kind of window for Yourself by drawing it in 3D parallel to the ground and safe it as library-part.
German but You should be able to follow it:
Dali_
The video by Hmooslechner is good (even if you do not read Deutsch!). There is also a good ArchiCAD Help article here: https://help.graphisoft.com/AC/20/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=AC20Help%2F03_1_Elemen...
I have attached an example of what you can create with a 'custom window'; I made a window with a Gothic arch and lead glass panels (tracery).
Our Infinite Openings tool does any shape and contains a lot of other capabilities: https://cadswift.com.au/products/Infinite-Openings.html
scroll to the bottom of the page for the reviews.
The videos in the link above a mostly old, though we have current user guide videos here: https://www.youtube.com/playlist?list=PLcbNDcsCZtyr9OfByqKKMVylqG7SUjGDj
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
