JGoode
Curved filleted box
Hello,
I want to create a curved filleted box. What is the best way of creating this?
I have previously made a regular filleted box but it isn't able to curve.
it is called as a sub routine then flipped and then called again to create a box.
HPRISM_ mat_prism, mat_prism, mat_prism, mat_prism,
	17, (ZZYZX/2), 0,
	chamfer, 1,
	chamfer,		0,			mask,
    (A-chamfer),	0,			mask,
    (A-chamfer),	chamfer,	900,
    0,				90,			4001,
    A,				chamfer,	mask,
    A,				(B-chamfer),mask,
    (A-chamfer),	(B-chamfer),900,
    0,				90,			4001,
    (A-chamfer),	B,			mask,
    chamfer,		B,			mask,
    chamfer,		(B-chamfer),900,
    0,				90,			4001,
    0,				(B-chamfer),mask,
    0,				chamfer,	mask,
    chamfer,		chamfer,	900,
    0,				90,			4001,
    chamfer,		0,			mask
ArchiCAD 27
Windows 10
Erwin Edel
If you look in the GDL Reference Guide and go to 3D Shapes > Shapes Generated from Polylines, there are commands like sweep, tube, revolve etc you would probably need one of those to achieve the curved shape you are after.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
The Hprism will fillet only "the upper" side of the prism.
So willing to achieve a "complete" filleted box - there have to be 2 of such elements placed: 1 "normally" and one "upside down" "glued" together (the statuses of the starting edges have to be set to "off")
Piotr
