Custom Corner Window
I just created a custom window and want to use it as a corner window, but it doesn't rebuild on corner (leaves parts of walls). Is there something a noob like me can do about it?
I'm trying to make a corner window without a mullion on corner. If nothing worked I would just use empty corner window and walls/slabs as frame...
Thanks, Lubos
(Intel Mac, AC11)
12 Replies 12
Could you post an image that shows "but it doesn't rebuild on corner (leaves parts of walls)". This might be helpful.
Thanks,
Peter Devlin
Also, did you use the subtype "Corner Window" for your new window?
Maybe this isn't necessary, but I thought so...
Peter, This is how it looks like with corner window function on.
Karl, yes, I did use the subtype "corner window", otherwise I wouldn't be able to select it from libraries in the dialog box.
Thanks, Lubos
Gents,
this is what I need to achieve. (at the moment done with slab/wall/empty corner window tools)
I thought, if I had a corner window with frame on top and in the bottom only, it would have no profile in the corner. I wanted to gang it with regular windows to side or a window with mullion to one side only (kind of C - frame)
It might be a dead end or it might just need some scripting which I know nothing about...
I am wondering, since you have made a top and bottom frame, trim,
and glass and saved these elements as a window, whether you could use
the window as a ordinary window not a corner window. Insert an
instance of the window in one wall, drag the edge to the corner, insert another instance mirrored in the other wall and drag to corner.
I have done this with empty windows and in 2D and 3D the corner
does not show. Very little editing of the 2D symbol is necessary.
Just a thought,
Peter Devlin
Lubos,
You can achieve what you need with a standard window 'fairly' easily, but it involves a bit of SEOing and a patch on plan. (Both of which are a bit nasty) You also can't automatically schedule the windows either as they are actually larger than they appear, but if you just need it to 'look' correct and still act like a window then try the following -
1. Create your window as usual. It can be a normal 4 sided window, although your 3 sided one should still work.
2. Place in the wall as a normal window, but stretch it so it goes outside of the wall (further out than you need) to make sure the unwanted frame is well out of the way. Set the ganging to turn off the thick line at the unwanted end.
3. Create a slab to act as your Operator (in blue on image), so it hits the wall at 45 degrees and extends to completely cover the extent of the window. Adjust in 3d to vertically cover the window completely. Put it on a layer that will be hidden for printing.
4. Use SEO to subtract the slab away from the WALL the window is in (not the window directly - It wont work!)
5. Rinse and repeat for the other half of the corner window all as before.
6. It may be worth grouping the SEO Operator to the wall so it doesn't get lost if the wall moves.
7. Create a patch to make it look lovely on plan. You may need to make it slightly larger then the SEOed area, as the thick lines tend to creep out from underneath which will look wrong. Feel free to add extra hotspots to help align it on plan.
Hope that may be of some help to you.
Image attached is the window after SEOing, and operators still visible.
The hidden operator is in blue. The patch is highlighted in green on plan and moved to one side for clarity.
Here is the finished article perfectly mitred in 2d and 3d.
Pete.
Mats_Knutsson
Mentor
Pete.
Great tips Peter! Does a string of silicone fix this in reality??
/Mats
AC 25 SWE Full
Tell me about it! In my limited experience they are a nightmare to keep sealed in 'real' life. We've had three fail very quickly from two different manufactures. A kindly chap on site decided to empty the contents of a silicone gun (literally the whole contents!) down one joint to try and 'fix' it. You can guess how neat this looked!
Has anyone actually used them and they have worked first time? Feel free to recommend any manufacturers!
Oh btw lubos, nice design! Can we see a larger picture of it when it's all finished?
