‎2009-10-18 02:34 PM
‎2009-11-22 09:32 PM
‎2009-11-23 12:41 PM
‎2009-11-23 04:48 PM
‎2009-11-23 10:52 PM
‎2009-11-24 12:18 PM
Master wrote:Is that necessary?
Thanks Braza, will you inform GS?
Master wrote:The option "box only" makes the object too much simple. I don't know how you built the profiled sheet, but I'd like to have the option to convert walls/doors profiled sheets to simple blocks (6 polygons) ... like a low polygon option for large scales.
Which MVO options would you like to be used for which object-option?
Master wrote:I saw you didn't use graphical hotspots to control the width and length of the object... Instead you used the A and B parameters, right?
What do you mean by number 4? Do you mean that you use only the values x,y,z from the standard list that were on the image you have posted?
‎2009-11-24 06:25 PM
Braza wrote:Unfortunately, I'm the guy to bring the realities here:)
... the object would be simply perfect and a MUST in all GS official libraries! 😄
‎2009-11-24 07:07 PM
‎2009-11-24 08:37 PM
‎2009-11-24 08:52 PM
Master wrote:I just wish they could do that much. I spend a lot of time fixing broken AC parts. For example, we've gone back to the AC11 casework objects because the AC12 ones are so buggy.
I think it is better that GS takes care of its own library...
‎2009-11-25 12:52 AM
