ā2014-06-06 11:43 PM
ā2014-06-07 09:42 AM
ā2014-06-07 04:07 PM
ā2014-06-08 03:19 PM
fristadm wrote:Either make a tall skinny slab or use a wall?
I can get it a slab but I couldn't find a way to rotate the slab vertically.
ā2014-06-08 03:29 PM
you can add your own RTO (rotate) commands in the 3D script.ROT X or Y or Z (or all three).
ā2014-06-08 03:50 PM
David wrote:ROT - I need to learn to spell.you can add your own RTO (rotate) commands in the 3D script.ROT X or Y or Z (or all three).
ā2014-06-08 04:06 PM
fristadm wrote:Since you're using 17, you should just use the Morph Tool to build this. You can model it in any plane, so no rotation would be necessary ... or model it however convenient and then rotate the Morph freely in 3D. Edit: Missed Barry's post offering this option... as well as ROT if you're scripting in GDL for a parametric object. If non-parametric, just go for the Morph IMHO.
it's a square plate and in the middle it has a 12 inch ring with cross supporting the ring in the middle coming out of the corners of the square. ... I can get it a slab but I couldn't find a way to rotate the slab vertically. I tried to upload a photo but it wouldn't go. I'm using archicad 17.
