Custom Patch Object
Pertti Paasky
Hello!
The Patch object needs some developing. I tried to find it but it is somewhere deep down in librarytree.. can't find it. My purpose is to save changes in plans by creating a patch object by the marque tool. It is supposed to have cloĆŗd linetype frame and a lable. It would have several parameters to make notes of changes in drawings.
It is of course possible to add parameters to a new patch object, but it is faster to have your own customized patch object. So is it possible to create such a typeobject ?
Thanks for help.
- AC-24 FIN - WIN 10 - HP Zbook -
ā€œA winner is just a loser who tried one more time.ā€
George M. Moore, Jr.
David Maudlin
Pertti:
I tried the Open Object by Subtype... command and navigated to Drawing Symbol > Patch, but this library part's scripts are all blank. I suspect that the patches are not created with GDL, but the result of application programming. So this may not be available via GDL.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Pertti Paasky
Thanks, David
PP
Should be found, opened and modified by following method:
- place the detail patch in the floor plan
- select it and choose "Open object..."
- open master script and select the name of the Marker Macro
call "Detail Worksheet Marker Macro"
- choose "Open object..."
