Custom arched door
I have a building full of this kind of windows-doors. How can I model this? Without going mad and loosing my head, I mean.
The top of the hole is a doble-curved surface, an ellipse tied to a straight line.
3 Replies 3
Rogelio,
Take a look at "Reveal SEO" object in the library below.
With this object, Solid Element Operation (SEO) shows in floor plan. Follow instructions how to add a door into the empty opening..
In your particular situation (6), you will have to perform first a SEO (addition) with a larger "Reveal SEO" object & wall.
For (6) situation, the object must be on a hidden layer. The rest is unchanged.
Not a perfect solution. May be this workaround can do the trick.
I'll give it a try and comment later. But it looks promising.
Rakela Raul
thank you Olivier !!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
