Yvonne
Custom door leaf - file size
Does custom door leaves increase file size?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
1 Reply 1
Yes, because the GDL file is saved (by default) in the Embedded library.
You can go to the library manager, list the files by 'details' and you will see the file size.
Usually a custom door leaf would be a fairly small file I would think, unless it is a very complicated door.
