Custom light fixture
I have created a custom light fixture using Boolean operations. I have an error in the script: 'SPHERE_RAD' isn't a valid parameter name. THis appears for like 12 lines of code. Here is what is AC10 is telling me I need to fix: Is fixing it going to be more difficult then starting over do you think?
sprism_{2} "Zinc", "Zinc", "Zinc",
13, 0'-0.0000", 0'-0.0000", -1'-6.8431", 0'-0.0000", 1'-7.3616", 28.59498338374,
0'-0.0000", 0'-0.0000", -1'-6.8431", 0'-0.0000", 0'-0.0000", 28.59498338374,
0'-0.2500", 0'-0.0670", 79,
0'-0.1830", 0'-0.1830", 79,
0'-0.0670", 0'-0.2500", 79,
-0'-0.0670", 0'-0.2500", 79,
-0'-0.1830", 0'-0.1830", 79,
-0'-0.2500", 0'-0.0670", 79,
-0'-0.2500", -0'-0.0670", 79,
-0'-0.1830", -0'-0.1830", 79,
-0'-0.0670", -0'-0.2500", 79,
1 Reply 1
Frank Beister
Have a look at www.selfgdl.com. As far as I can see is missing your command the material information (the forth value of each edge after x,y and status) in the path definition.
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
